Cape Cora Passive Radiators
Don
7 Aug 2003
Aberdeenshire
Anyone get any experience of Cape Cora 642 radiators?
Pretty sure there's someone here that uses them?
Just looking for some info on performance for cooling a C2D and 8800GT with them (probably 1 for each unless anyone advises different).
Very nice - haven't seen those in ages - like the fact that you can buy them individually and plumb them together for as large or small as you need - you going for the gold or the black?
Will be going with the black ones, looking at sticking one either side of my case, I've only been able to find one review that showed one should cope with a 160W load CPU, but I don't know how thorough they were with their testing, as you would need to run Prime or something similar for several hours to see what temperature they level out at which I don't think they did.
Hmmm, that test was done using SnM, but the reviewer gives no indication of duration, so if he just ran the defualt test (15mins?) then it was no where near long enough to reach equilibrium.
WJA96 is yer man when it comes to cape cora, he's had them & sang there praises frequently ;)
Yep - They're the dogs, but you need plenty of them. I was running 10 to cool a Prescott 560 (at 4.2GHz - possibly the hottest CPU ever until Wolfdale) with 4 more to cool the Graphics (7800GTX) and two more to cool the chipset.
You need all the pump capacity you can get (DDC2 18W or better) and the more 'buffer' you can supply in the form of a big passive reservoir also helps enormously. You do need to mount them vertically as well. Mounting them horizontally (in hindsight - it's obvious!) stops airflow through the fins so it just heats up. You also need to use 3/8" piping to match the inner diameters and quick-release couplings are an absolute requirement if you ever want to take the side panels off your system again sensibly.
You could probably get away with 6 on an M0 E2180 if you weren't overclocking, but anything more than a dual-core and you're you're going to need 10-12 sticks. They work exceptionally well, but you can't defy the laws of physics. And don't underestimate the size of them. They're 42cm high with a further bit top and bottom making them near-as-darn-it 50cm tall in use so you need a big case to mount them to. Coolermaster Stackers and Lian Li V2x00 series work well.
The temperature of the room is also of vital importance as you need a temperature gradient to work with. The colder the room, the better they work (again, you're probably thinking that's obvious).
I did look at bolting 12 of them on an outside wall and pulling the pipes back into the house, but in the end I just decided air conditioning was a better long-term option. It cost me about £2k to properly air condition my office at home, but it was worth every penny.
Silence is golden though. The Rasta colour option is possibly one to bodyswerve as it looks hideous in the metal.
No - 3 loops - 1 x DDC2 18W (CPU), one 10W (graphics) and one off an XSPC 150lph combination reservoir and pump (chipset). It's the length that's incredible. The CPU loop was something like 7m long with 20 right-angle bends in it. You need all the pump pressure you can get. I'm told once it gets going, any pump could keep it ticking over, but you need lots of oomph to start it moving.
With the 560 (about the same heat output as a clocked Q6600) it would settle at around 65C under load in a warm room. I had no fans on that system at all though and it was REALLY quiet.
Cheers, think I'll give it a go, won't be looking for stellar cooling performance but if it keeps it under 70ish full load then I'll be happy.
But surely with that sheer number of them required, the costs must be uneconomic? Are these any better than using a house radiator or a car radiator or just multiple 120.3 rads mounted horizontally?
The 6 tube bundles aren't that much more expensive than a PA120.3 and it looks like it'll be a simpler and cleaner installation externally.
Any minute now the Anti Aluminium brigrade wil start freaking out.
"mixed metals -mixed metals freeakin 'ell mixed metals get ready for the melt down"
:D :D :D
Had a look at that MO-RA rad and it's a dense fin radiator, think you would need to mount it horizontally to run it effectively as passive.
I'd say the temperatures look low, but the basics are correct - stand them vertically in a cold place with water passing through as fast as possible for best results.
