Dual 3870X2 with COD4 early results
Some people are reporting performance is very up and down in COD 4 with 3870x2's. 100FPS when you look in one direction 30FPS the other direction. I'd prefer a steady 70FPS.
I think it would be good to know what the performance is like with 2x 3870X2 in Crysis, as if it can pull that off at a playable rate at that res possibly on high or very high then it might be worth the money.
Its a bug that also affects crysis. I provided ati details of this and a fix is being worked on. Something to do with the gpu's dropping to idle mode when they shouldn't be.
http://www.fudzilla.com/index.php?option=com_content&task=view&id=5842&Itemid=1
Fud have been coming up pretty good of late I have to admit.
They reckon average of 80FPS @ 2650x1600 4X FSAA :) but peaking at 140 fps. Pretty damn good, and really where these cards should be used :)
Matthew
That screens pretty suspect at the same time, its like whoever took it purposely got it at a weird angle, looks like the game area in the pic is inside a small room with a guy looking at a wall.
