I've never overclocked before, I'm now looking at the clock of 2.4ghz and wishing it was 3ghz, can anyone do a quick walk through guide of how to do this please?, as I'm a bit of an old fanny and I don't know what I'm doing![]()
Well the easiest thing would be to read through a few pages from this thread. you should find all you need. 3ghz is easy to get even on stock cooler. ( you ll be flying with yours)
so
- Get CoreTemp, CPU-Z, orthos or prime to test clocks are stable.
- check out the mobo section and see if there is a thread for your Gigabyte P35 if you need to know what everything does bios wise.
- Disable the speed stepping features in the bios. (gone blank for their 2 names right now.)
gtg, will finish post latter
