It seems that way to me, all you've done so far is told someone who works in IT that they don't know what a VM is and then stuck around shouting SANDBOX!! as the only rebuttal to any sort of comments regarding elegant security models.
Just because you spent the time setting it all up doesn't make it a desirable thing to do.
It was implied that an advantage of macs was not having to maintain upto date antivirus and antispyware programs, all I was saying that you don't have to have antivirus and antispyware on windows by using methods like sandboxes or extensions like noscript. So if the op wanted that feature he didn't need to spend more and buy a mac for it. I can't believe that such a horde descended on me for suggesting that, it's just an operating system. The reason I personally use sandboxie is because it offers protection against every virus, even new undetected ones without causing me any hassle.
3. Again it is a myth that Macs are expensive. Name a small, lightweight laptop with long battery life that you can get for £650. You can't do it. All you end up with is large, heavy rubbish.
HP Pavilion tx2050ea £699
1.92Kg (macbook 2.27Kg)
22.40 x 30.60 x 3.87 (macbook 22.7 x 32.5 x 2.75)
So not large heavy rubbish.
		 with all the VM/sandboxie talk.
