well i monitored while playing cod4 for about ten minutes everything is goin ok except the gpu usage its drops down to bottom quite a bit and sometimes for a few seconds,is this normal, cuz i thought in game the gpu usage should be constant??
sorry jakus but i was curious lol, went into cod4 with crossfire enabled but only getting more or less the same fps as a single card 30-50fpsill switch back to a single card now and then do some monitoring
never done it b4 tbh, sounds dodgy lol
OK RTS.....only Shooters heresorry the game was CoH, (company of heroes)
lol,the link you gave me is a different bios ver to my powercolor card or doesnt that matter jakus, and another thing is i dont own a floppy to back up my old bios, or can it be done another way
Don't worry about that....would You prefer one that does not fix the problem
right i have downloaded winflash 2.0.0.2 and have downloaded the bin file link ui gave me and the fan on these cards are the flower type http://www.overclockers.co.uk/showproduct.php?prodid=GX-079-PC
Just for your information, I have the exact same cards. Checked mine and they are using the 7.5 version bios.
GPU-Z 0.1.7 shows the bios as version "Ver010.075.000.002.000000", with clock speed of 796/1170, default of 800/1170.
I've saved off an image of the bios, so let me know if you want a copy.
Shame the fan is on full whack all the time though - maybe a later bios will fix that.
Well it's looking like the Card might not be downclocking then it's easy to comfirm by looking in the CCC at core speed.
I Believe the fan on Your cards connects straight to a 12v rail with a 2 pin connector a simple inline resistor/fan controller will do the Job so it's outside of any onboard bios/controller to be able to control its speed
mornin jakus, the clocks are 800/1170
providing You do not increase the vcore You will not risk it at all , I would think 3.3-3.5ghz should be possible, also try the PCIex bus up to 110 but just to see if it helps the bandwith on the second card @X4 but just as a test don't leave it there.
