Have BIOS 504 yeh.
Well just played Crysis and small FFT's are fine at this 3420mhz (380x9 @ 1.4875v)
Yep, seems the bottleneck is my CPU. I suppose i won't notice much difference between 3.4ghz and 3.6ghz, it's just my parts are brilliant and my settings are perfect...pure luck not letting me get higher OC is VERY annoying, when there's people with VID's under 1.2v
, with them, 3.6 is merely a case of increasing the FSB, then exiting...
450x8 is very possible for me, but like i said, my RAM won't run above 800mhz in 1:1 ratio, won't boot, however it will cap at about 1000mhz. This means at the highest FSB i can get at the next closest ration (5:6), would be 416 FSB. This would bring my clock to 3.33Ghz.
With faster RAM (1066mhz), i wouldn't have to OC it to go further, i'd get roughly a 445 FSB at stock 1066mhz, which will OC a little at 1:1. Will take me to 3.6Ghz in theory.
