- 7 Nov 2004
- Southampton/Oxford
Indeed, bloody smooth and everything runs like a dream!
Is the driver support good for Vista x64? And do all games from XP 32bit play fine on it? Tempted to try it with all these comments![]()
It soon slows down![]()
Damm spoke too soon. After installing all the updates there is and then activating my copy(oem ultimate from ocuk yesterday). I did a shut down and on reboot the system locks up on the scrolling green bar screen but with boot up after a reset and selecting load windows as normal, but reboots fine on a restart but locks up on the same screen on a cold boot.
Any ideas that could be causing this? are there any issues with the lastest updates?
sys: Asus commando, E8500, x2 1g pc9200 flex(another 2 to go in) 8800gtx, sound card as mentioned but no drivers installed, x 2 320g maxtor diamond max 17 in raid 0, x1 pioneer ide dvr112d, logitch g15, ms optical rat.
On system info no conflicts aprt from the being no drivers installed for the sound card.
any insight would be welcome.
Finally people are realising Vista isnt bad like some people try to make out.
