4400x2 @ 2.7ghz. I could only get stock stable, if that with Crysis. I think with the X1900XTX I got around 7000 3dmarks. With latest drivers probably around the same, around 9850 stable in 3dmark, but not stable in games. No I didn't use NiBiTor. Just rivatuner.
Currently at 725/1800/2100 on my Gainward Golden Sample. Was thinking about the BIOS mod but not sure it would work on it as it uses a custom PCB.
I guess flashing the bios is similar to flashing my ATI X1900XT to XTX, basically at stock it'll perform faster, without needing rivatuner clock util? Not flashing it, but here's snap from that flash util.
Fine in Tomb Raider though, and definietly smoother framerate than the 1900XTX (although I haven't played it recently, perhaps ati have improved drivers) in legend on outdoor scene (quarry) now at higher resolution smooth.What the...unstable in Crysis even at stock![]()
Rivatuner is for safe ocing. NiBiTor is a BIOS modder and it would be a bit risky for new users.
As I mentioned in a earlier thread. 730/1100 would be the wall for non-voltage modded 88GT. So your result is expected.
Hey mate, did you oc your CPU and RAM as well?
@2.7ghz CPU /198mhz memoryActually mine needed bios volt mod just to get to 720/1800 and I'm not entirely certain it's 100% as so far I've only really tested it with Crysis. My mem won't even clock over 930 (1860Mhz) without artifacting/crashing/restarting in games.
So I'll say OP's clock is very very good without mod.
Looks like it managed just fine without volt mod so I'll just leave it and be very happy![]()
"base system" was stable with my old ATI X1900XT@2.7ghz CPU /198mhz memory
Under 40 under full load (Accelero S1, with 12cm fan)
Fresh install
Yes, with rivatuner 600/900.
