VMware or Parallels??
Permabanned
29 Mar 2006
Manchester, UK
I wants to install Windows but what shall i get
- Parallels Desktop 3.0 for Mac
or
- VMware Fusion
They are both the same price.
Also I'm sure i read somewhere that you can install Windows using Boot camp but also open it virtually inside OS X.. Is it possible and if so which one can do it?
Ta :p
18 Jul 2006
Midlands
VMWare Fusion, much better. You have the ability to search through Windows apps like spotlight does, and then choose to run just that application.
Look at this video at 1:12: http://www.youtube.com/watch?v=JIApJMzGzDQ
VMWare Fusion > Parallels. ;)
Edit: Bear in mind that video was posted 9 months ago, so much more features will be available now too.
28 Jul 2004
can they both be used for other OS's too? i'll be gettin one shortly and will want to run linux on a VM too. Does this requirement sway the decision at all?
11 Dec 2003
I've found that Parallels runs faster than VMWare, I don't think you would go far wrong with either product to be honest.
15 Apr 2003
Hertfordshire
Yes, AFAIK.
I have run Ubuntu and Win 2000.
However, there are quite a few "complete" VMs whcih you can download for Fusion - not certain this is available for Parallels.
17 Oct 2002
I'm using parallels for autocad and it seems pretty quick.
The lst time I ran VMWare Fusion was in the beta tho :( so can't really say too much in comparing them.
Looking at the video posted above, VMWare and Parallels still seem very similar. You can run windows apps in coherence mode, similar to the VMWare mode.
http://www.youtube.com/watch?v=rN9jNNeEd98
17 Feb 2003
Northampton
As I said earlier pull a trial version of each and give them both a bash, if you like one more than the other then keep and ditch accordingly.
Steve
