A physically compromised system is a compromised system. Same trick, different vector
So what is "THE" point?Your totally missing the point![]()
Yep that's right, just as booting with a live linux CD bypasses windows user account passwords, giving instant access to all windows drives/partitions. Which also works on vista as well. I've tried it!
You said that.
But this exploit is nothing like booting up a linux boot cd and bypassing local passwords.
You said that.
This exploit lets you unlock a windows PC. We're talking computers on domains etc. Something that prior to this was (to the best of my knowledge) not possible!
=/ Absolutely ridiculous exploit and I still can't believe it hasn't been sorted already.
anyway on topic..
Seen around a few "certain" forums that vista pc's just BSOD if you try this? Suppose thats an improvement if its true!
The problem is that memory access is part of the firewire specs, so you can't just shut that side off.
It's also worth noting that this exploit can't elevate privileges which is going to limit it's usefulness, and requires direct, unsupervised access to the PC...
Wouldn't surprise me, Vista is a lot more secure than XP, and allows a lot less user stupidity to affect that security.
Yeah read that in the link - Memory access okay whatever but being allowed to modify parts of the memory as crucial as this? Still baffles me why anything other than the kernel and CERTAIN drivers has permission to do that when the systems in a "locked" state.
Yeah, I would expect and hope vista to not be as vulnerable.
Still not sure if the BSOD is from the fact that the exploit is slightly difference in Vista and its just rewriting some memory that's causing a BSOD or if the Kernel is detecting its being modified and BSODing itself, hopefully the latter.
Either way I'm still amazed that something relatively simple like this works.
Where is the documentation of this "vista" BSOD? No-ones posted anything to do with this, only that its not been properly tested. It wouldn't surprise me if this still worked with vista too...
And why exactly does windows still let a firewire driver read/write to the memory, specificially parts of the operating system like this? =/
He demonstrated it in 2006! common Microsoft!
But as mentioned its a problem with the specification, rather than the OS itself?
Yer I have... just pointing out that its not that hard thats all
Stelly
