Hi,
not sure if this should go here or in software but I will try my luck with you guys
Currently rebuilding a friends pc which is fairly basic, a 3ghz skt478 celeron, 1gb ram and a 9800Pro, we are trying out Vista Ultimate (my disc to see if it will run OK) 32bit, it installs fine but I cant seem to get Aero working properly, transparent windows for one thing. I have downloaded and installed the latest ATi drivers but it still gives me issues.
Also when I check device manager it has an exclamation mark on the 9800 Pro saying something about the drivers being stopped due to an issue (pc is off now so cant properly check).
I installed the motherboard drivers OK so not sure what the issue is.
Do I need to do something else? The computer seems perfectly up to the task of running vista, I can go back to XP but he would like to have Vista.
Cheers
Cheers
