I canny copy and paste any more...HELP!
if its a usb keyboard try another port
also is the keyboard running thro a kvm switch?
Is it a USB keyboard and are your other USB devices working properly?
If the other devices are working it will be a keyboard fault.
update the drivers on the keyboard (firmware/software etc), if that doesnt work then your keyboard is faulty. and will most probably need replacing. i doubt it will be an American layout causing the problem.
Sounds like ole32.dll may have become unregistered.
Try the following;
Click start ->run and enter the following command ;
regsvr32 ole32.dll
Let us know whether this fix works.
Cheers
HaX
