The "don't use a harness without a cage" point regularly crops up on forums, but around 25% of the road rally cars used regularly in the UK don't have cages and use harnesses.
You are also told on the internet not to use a cage without a helmet - which again brings me back to road rallies (and I believe enduros?) where the use of a helmet is expressly forbidden, cage or not.
the rolling radius, rev limit and FD combined with fifth gear equate to 154mph on the limit in fifth, my car hit the limiter as most do (if the owner attempts it). That's not reading the speedo, that's using 100% accurate maths - although you could go further and factor is tyre shape at that speed i.e. an increased rolling radius and therefore a higher speed than gearing alone would allow.
