I'm guessing my ping will go up too ?
As far as target SNR? It's at 100 now (%)....is there any way I should go about tweaking this?
I dont think your looking at the right thing, BE generally support 3.5db 6db 9db and 12db profiles, not sure what your looking at as a percentage. its impossible to get 100%SnR.
If your on fastpath then the router wont report any FEC errors as this is part of the interleaved error correction.
BS
Downstream Upstream
Margin [dB] : 3.5 2.0
Attenuation [dB] : 36.5 17.0
OutputPower [dBm] : 19.0 13.0
Intrinsic/Actual Bandwidth %
Upstream : 102
Downstream : 80
Available Bandwidth Cells/s Kbit/s
Downstream : 35136 14898
Upstream : 3882 1646
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 25 db 6.5 db
Noise Margin 10 db 22 db
Got activated this afternoon, very pleased with the speed.
Bandwidth (Up/Down) [kbps/kbps]: 1,321 / 20,859
Line Attenuation (Up/Down) [dB]: 3.5 / 9.0
SN Margin (Up/Down) [dB]: 7.0 / 6.5
Tech support were great as I didnt have a clue how to set it up, wanted to use my old router but it demanded a username/password which BE dont use so im on the (huge) BE box.
