Aluminium Mousemats
19 Oct 2007
Delete *.*
I recently purchased a swanky £30+ aluminium mousemat.
All my workmates ribbed me, but it is amazing!!
Only problem is, it has a fast side and a precision side and the other night while hammering some 12 year olds i knocked it off the desk!!
I now do not know which side is which, any ideas??
Take mouse mat, aim at 12 year olds head.
See which side misses and which side hits the kid the fastest.
Result.
Surely the smoother side is the fast side and the rougher side is the precision side?
And if you can't tell the difference you have to wonder whether it's just a marketing gimmick
i use a SteelSeries Experience I-2 which is around the 35 quid mark but use to have all that stuff paid for by sponsors when i use to play cs, i would never give it now that i have to pay :(
tip: if you are gamer use glides on your mouse feet for a more smoother finish across the sheet.
it sounds like you have the SteelSeries 4D One side for roughness and one side is smooth. Simply turn the mat over for which ever side you require and place on base. You will tell straight away, i can tell in the dark what surface im on depending weapon choice.
I'm using an Everglide Titan, mmm, smooth.
I was fortunate enought to beta test the Everglide before it was offically released and i have to say i was very impressed. However it did not perform well with the MS explorer range imho. Neither did it perform well across the board with controlled gun spray in cs but im anal like that sorry :(
got an icemat II here with my mx1000, when I can be bothered to clean them its so smooth that sinatra would be proud. 35 quid for a mousemat aint to bad, how about £800 on a keyboard to go with it?
