Wider lower profile tyres = lower pressure?
17 Dec 2002
Northampton
If i go from 205 50r15 to 235 35r19 how should i adjust the tyre pressures? do they need to be lowered? i tried searching for a calculator but there don't seem to be any rules for this.
I have nothing to add beyond the fact I'm struggling to think of a car which comes with 15 inch wheels and won't look absolutely ridiculous on 19's.
You are aware its going to cost you 500 quid every time for a set of half decent tyres in this size, yes?
Are those sizes right, by my reckoning your rolling radius is going to change by a huge amount on those tyres.
Thats a 10% increase in rolling radius! :eek:
*Edit*
to keep it *just* within the 3% tolerances you need 235/25 19s... good luck finding them, and if you do I hope you know a good chiropractor.
Haha, I was thinking this also.
Just a bit...
White rings are the old size, black and grey is the new one.
InvG
ok so i didn't explain myself properly in the first post cos i was in a bit of a hurry.
it's not my car, so it's not my problem how expensive the tyres are or how accurate the speedo will be.
but i have fitted the wheels and don't know what to set the tyres to.
for the guessmiesters i will add more clues and wait for you to work out what car it is.
front tyres are 195 60 r15 and the rears are 205 50 r15
think i'm gonna just put them at 28 all round and let the customer work it out for himself.
the tyre pressures (to use) should be written on the inside of the fuel cap, failing that ring the dealer - its only a phone call
the problem is though, these aren't OEM wheels, so the details no the flap or in the owners manual are irrelevant and the dealers aren't going to give you an (accurate) answer.
You are a professional and you think that the wrong rolling radius is 'not your problem' and feel its good to ask on OcUK about tyre pressures?
Who do you work for so that we may ensure we never, ever use their services?
Jeez...
I do hope you are not charging your customer for this bodge work?
