Post Your Home Cine & HiFi Kit...
its a 47inch wide stand
the brackets like a wallmount bracket, if the tv mounting was even a cm wider it wouldnt have fit
its a iMOUNT 5610, it cost me around the £200 mark
Samsung R73 32" (I want a 50" now, this feels too small :()
Xbox 360
V+
Some cheap sony DVD player
Some fairly cheap sony surround sound system
:p
Not great but it works for me :)
Oh, and my photo on the wall :)
bit of an up date from a couple of months back.
before
After
dvd player packed in so im using my PC to watch DVD's via DVI>HDMI cable. Also got me V+ and the Mrs got me a 360 Elite for my b-day last week:D
oh and the sub is behind the telly ;)
Nait 5i's are wonderful little amps that can drive speakers they really shouldn't be able to. for your setup, I'd suggest:
- Epos 12.2
- N-Sats on N-Stands (these are supposedly ok with the proper wall mounts too)
- Linn Katan
- Dynaudio Focus 110 (I use these with Naim equipment to great effect)
- Neat Motive
Cheers for the suggestions. Eying up some Epos 12.2s as they are now being replaced so they are being sold off cheap everywhere. I have also replaced the bi-wire Linn K20 with Naim NAC A5. Its made a huge difference, even with the link plates now in place on the old B&W's. I was going to make some jumpers but it the NAC was far to much like hard work to cut and strip and it is far to inflexible!
For the mean time the two 5i's are making the old B&W's make music like I have never heard them before. Such a difference over my old Denon av amp.
Dave
My little lot was quite cheap
Sammy 40" 1080P Mission 733 £31 off ebay :p Tannoy mx centre £10 off ebay Sony STR DB930 Yamaha sw225 Sub Mission 771 as rears.
The HTPC is a C2D @3GHZ in a Lian Li v800 case
Sounds ok for the little room its in.Will be all moving to a purpose buit room soon though.
Just received my new Sony KDL-32S3000 :D I'll post pics of it later.
Quick question for all you LCD geeks out there - I read that it's wise to let your new set adjust to the room temperature before turning it on. Is it worth it?
Just had my TV and speakers put on the wall, didn't want to chase the cables behind the wall as it's rented apartment.
Very classy
How are those speakers being mounted to the wall?
The guy who mounted it all put screws into the wall then just hooked them on! They have two mounting options, a slot like you'd get for putting your phone on the wall, small and big hole thing (which is how it's done) or you can use a speaker stand and screw it on!
Glad you like it, I'm very pleased with it all!
