Seen some reviews on these and they seem to be better.
http://www.digitimes.com/mobos/a20080317PD209.html
Even they are best off saving another £100 and going intel to be honest.
In the world of budget systems, another £100 is a lot of money. If you're on AM2 and have a compatible board, why bother buying a new motherboard and having to go down the windows re-install route when you can just stick a £119 Phenom in?
[heresy]Not everyone overclocks.[/heresy]![]()
The B3 steppings are still terrible overclockers. Anandtech said they couldn't get over 2.6ghz...which is major crapola.
 where did you read this, i thought the only info we had fron Anand was that the B3 steppings perform exactly the same as the B2 with the TLB Fix disabled? it was a B2 they got @ 3.0Ghz to boot into windows, but only stable for apps/games @ 2.6Ghzwhere did you read this, i thought the only info we had fron Anand was that the B3 steppings perform exactly the same as the B2 with the TLB Fix disabled? it was a B2 they got @ 3.0Ghz to boot into windows, but only stable for apps/games @ 2.6Ghz
