First time we found that out was when we were doing 110mph in the Arizona dessert...![]()
Was in a daweoo mitiz the other day. Wow electric mirrors I thought, wrong electric mirror on the left side manual on the right. Why?
7) S-class no-where to put your right foot, so it ends up either hovering above the pedals, or on the floor infront of them in a rubbish position. Why the hell didnt they put a foot rest to the right of the accelerator?
electric handbrake on new passats, wouldnt be half as bad if it was actually on the centre console and not on the far right side near the headlight switch.
Dont they hold the handbrake for a few seconds?I had fun with that when I had a Passat as a courtesy car. What makes it more fun is lid for the storage bin where the hand break should be won't close unless it's been fully opened. So when you're trying to work out how to use the hand break you then realise you can shut the storage bin either 9just to make you feal really stupid).
When I did find the button I pressed it and the LCD display on the dash told I needed the foot break on. I wasn't looking forward to the next hill start, I hadn't relised that I could just pull away and it would turn the hand break off.
mk3 mondeo indicators, where you press it lightly and it singnals a few times, if you cancel it yourself it would sometimes signal the other way!
Ford headlight stalk.
On most cars, you push the stalk forwards to lock on main beam, bring it bank central to turn off main beam. Pulling the stalk toward you will flash the main beam and then return normally by a spring.
On my Focus, both actions are done by pulling it toward you. So you pull it halfway for flash and it springs back, or all the way to lock full beam on. Unfortunately, it requires only very gentle pressure. The amount of times Ive gone to flash an oncoming driver only to lock the full beam on, blinding them...its about the only thing I don't like about my car![]()
Headlight bulbs on Smart cars....changing one is akin to sticking your hand through a letterbox, and then reaching around a corner to release the clip by touch alone, whilst barely being able to reach it. Oh and if you drop the bulb you will *never* retrieve it again.
Polos from around 2002 onwards and many modern VAG cars that use a standard H7/477 bulb have a crap rotatable clip to hold the bulb in place which once released is stupidly difficult to replace as its difficult to twist it hard enough. Old style conventional 'bent-wire' clips for the win.
Any car where access to change front bulbs on is gained through a hatch in the front wheelarch. Fiddly, means you get messy, and you have sod all way of seeing what you're doing. Mazda RX-8 worst I've ever done.
Battery location on many modern cars, which precludes easy replacement of the battery without removing vast quantities of brittle plastic trim, rubber seals, or even occasionally windscreen wiper mechanisms! Audi A4 and Passat diesels are especially bad...
And uess who works at halfords doing this sort of crap day in day out?![]()
Woah, your e-penis is hoooooooooooooge
