- 27 Aug 2007
- Surrey
Hi,
Please can someone in the know help... I have the XFX 780i MB, 2x 8800GTS (G92) and am thinking about buying a Lian-Li PC7 case.
I like the Lian-Li PC7 because it's compact, the HD mounting tray can be removed and because of the 120mm blow-holes etc.
I want to water cool the MB, CPU (E8400) and graphics cards. I was thinking about going for:
2x EK-FC88 GT/GTS (G92) or... 2x XSPC Full Cover Razor 8800GT/GTS (G92)
1x EK-NB 780i
1x EK-Supreme CPU - Plexi or... 1x D-TEK FuZion CPU Block
1x 12V Laing D5 Vario Water Pump (best/most powerful ?)
1x Black Ice GT Stealth III
Reservoir??
I plan on mounting the radiator on-top of the case, on motherboard stand-off pillars... if these will screw into the radiator?
Is the Laing D5 pump powerful enough for the triple radiator, MB block, CPU block and 2x GPU's in SLI? In addition, do I really need a reservoir? I was thinking about a fill-port to save space, however, if it makes the pressure/flow-rate better then I'll make room for a drive-bay reservoir
Thanks in advance
1x EK-NB 780i
Reservoir??
Thanks in advance
