http://www.pcmag.com/article2/0,2704,2243185,00.asp
That guy says an EULA is unconscionable and I'm inclined to agree.
That guy says an EULA is unconscionable and I'm inclined to agree.![]()
the point is that under UK law, you cannot add clauses to a contract after its been completed.
once you buy the software, its yours under the terms of the contract, and the contract does not refer to and cannot refer to the EULA.
Can someone answer this question for me. I've just sent back a laptop to HP and they're going to replace the system board under there extended warranty. Installed on it is a OEM copy of Vista Ultimate that I bought a couple of months ago, and installed myself. Will I need to purchase a new copy of Vista?
AS far as threads like this go, both sides of the arguement could be correct.![]()
What do you do if your mobo breaks outside of its warranty period? You have to go out and buy a new one, obviously. However, clearly a year on you are not going to want to buy the same mobo as you had before, as for the same money you can get one which is far better. What happens with your OEM version of Vista then?
Depends if you built the machine yourself or you bought it from a big OEM.
If you bought it from a OEM then you need a new licence, if you built it yourself, you can buy another mobo which is supposed to be as close to your existing mobo as possible.
Burnsy
but if the motherboard breaks outside of warranty period, you would still need buy a license because the motherboard isn't under warranty.Depends if you built the machine yourself or you bought it from a big OEM.
Burnsy
snip
On the subject of Vista licensing I'm sticking with XP and Linux as I can't be bothered with the hassle TBH
Just throwing this into the general melee, if you install the software without clicking the "I agree to this EULA" (and yes this is possible with a little effort and the right tools)
Surely this would be editing the program in a way that isn't supported though?
Burnsy
Like I say, though, you arent going to want to buy the same mobo a year on. To start with, it would be pretty hard to get hold of, and secondly surely you would want to get the best mobo you could for your money? That is a slightly unreasonable clause that MS are putting in there, in terms of breakdowns.
gareth170 said:but if the motherboard breaks outside of warranty period, you would still need buy a license because the motherboard isn't under warranty.
Hello Sp!ke, if you purchased Windows legally, why would you want to do the above in the first place?
The licensing terms are exactly the same for both Windows XP and Windows Vista.![]()
As said it was a slightly tounge in cheek comment, but maybe in a court of law.........
I'm sure in a court the judge would take into consideration the spirit of the law and rule accordingly.
I doubt this would go anywhere, but then as so aptly been shown, I am not a lawyer.
Burnsy
