 - 18 Oct 2002
 - between Blandford Street and Mars
Of course, another option would be to leave the compression where it is, change the cams and go forced induction.............![]()
Mo' blow, mo' go!
******** to forced induction, just found this vid that shows what a well setup high compression N/A B20 build can make:
263whp
Hey m8
Great that you're gonna upgrade the engine m8 but it went great when I had it (as you know). Can't understand the compression issue, but I do know it was running at 10:9 instead of the standard 11:0 just slightly lower than standard for longevity (if that makes sense).
That's WHP, so about 290ish at the fly?
Seems a tad optimistic if I'm honest though![]()
And another N/A B20:
This one sounds insane when VTEC kicks in
That one is 210whp apparently, seems more realistic.
You know it makes sense
