- 27 Jul 2005
- The Orion Spur
GO GO GO !!!!!!!
oh, and post your comments
Dam just turned it off, jericho was giving me a headache, probably coz it sucks.![]()
the browser also feels quite a bit nippier.
Can the PS3 stream mp4 files from a PC?
EDIT: I've noticed that the ones that gave me trouble before, that wouldn't play at all, take slightly longer to start up than the other files, but then play fine. Bringing up the info screen, they're identified as MPEG-4, rather than DivX (these are XviD files I'm talking about) anyway, great, just flicked through loads of XviDs on my server, and all play except that one file I mentioned before.. I'm delighted![]()
Using TVersity yes its straight forward.
If you want to use Media Player to do so you will need to look up how to hack the registry for media player to see MP4 files.
T.
Wow, I totally didn't know about that!The Media Player hack is easy, it's just a .reg file that you double click, job done... it can stream .mp4 files.
I've uploaded it to rapidshare
http://rapidshare.com/files/102228766/v4-WMP11-MP4.reg.html
Can confirm it's 100% safe, just a 5k registry key, that makes media player library add MP4 files, and allow them to be streamed to the PS3.
I've tried it on my Vista Ultimate x64 system, and an XP 32bit system.
V1N.
