Rainbow Six Vegas 2
Yea we can do *** co-op, I think I'm only like... 3/4 chapters away most before getting that achievement, I'm pretty sure I've yet to recieve it. If it doesn't unlock your realistic achievement, we'll just go through the game any ways to get it you, no worry from me.
Nice one. I'll remember my cricket pads :p
Need a couple of people to go through Terror hunt on realistic.
Count me in for tonight mate, if you fancy it.
I have a couple of presents to prepare and wrap before hand, but then on for the rest of the night, from 6-1am basically, sure Simon will play at some point too. We have some ranked matches to play, as well as some co-op but I can always fit in a Terror Hunt or three. They generally are really good EXP too, nearly as good as the Attack vs Defence EXP.
Sure I've just done them all with Wyrdo apart from Murdertown and killhouse.
On Killhouse you can pretty much max out the ACES ranks, Shooting thru a wooden box whilst waiting guarding a doorway etc.
Wyrdo, I'll give you a hand too. Done them all now so know the best way to do each.
5v1 whoring sounds good too, have to make sure 3 of the kill are with 1grenade too ;)
I'm up for that too :)
Im up for some of that :)
We were doing it for fun :p
To be honest though, although it wasn't for the achievement. It really is a quite brilliant map in my opinion. Great for EXP (especially that choke point with the double doors, and then the single door the right, 2nd room after the Expo). Bloody hard, but me you and Zico did cream that level in the end.
It might be worth increasing the denisity to Maximum, as I believe this spawns more enemies.
I'll be up for the 5 vs 1 whoring too. It might be worth figuring out a system, so we can get the 3x wins in a row too for the ranked matches.
