Finally made the jump to a mac.
Man of Honour
1 Oct 2002
After many years of thinking macs were form over function, I decided to take the plunge, and got a 2ghz Macbook, which was a refurb bargain.
Completely different experience to a pc, I was quite surprised how easy to use it all is, my mind was obviously still thinking of clunky macs from years ago. Its a breath of fresh air next to my old laptops.
Not in here.
Pics or it's not real.
Want bread with that?;)
I'm thinking about taking the plunge. I'm using a MBP at home that I've borrowed, if I can get it to do what I want then I shall be getting myself one. :)
I've got a Macbook pro I'm using at the moment so far so good - had to do a bit of unix fiddling to get it just right so far, and once I get my windows mobile to synch all the better - just need to try and see if it'll synch with some form of PIM and I'll be sold.
I was semi worried when I made the switch, mainly about compatibility issues. I soon found that there were loads of alternative programs to use... I found that my worries were unfounded! :)
Do it FF, all real men use macbooks, i just put it under my arm and walk to class and let my bulging lats(170kg) and inner bicep heads hold it firm. :cool:
*this may of may not be true*
I've got the new MBP in the basket at the moment...... just got to press the buy button (my bank balance is holding me back at the moment:()
If you don't buy one Justin will sacrifice small kittens on the hour, every hour.
