- 27 Jul 2005
- The Orion Spur
NEVER EVER FORWARD PORT 80, 443 to any machine on your network unless you are running a HTTP or and SSL server (neither of which the PS3 is running).
You only need the UDP ports on that list forwarding (trust me, I have them forwarded). I need to check that list as it should only be port 3658 (I think).
Either way it won't affect your download speed, just didn't want to see people forwarding the wrong ports and leaving their machine(s) open to hacks/vulnerabilities.
I believe the last user who had this problem had VM investigate and it turned out to be an incompatibility with one of the modems they supply (He got them to provide their other brand modem and his problems disappeared).
rp2000
just out of interest how would my machine be open to attacks, I've only opened those ports for the PS3's IP address, not any of the machines on my network, or do you mean that the PS3 can be hacked ?, in fact, couldn't you just whack the PS3 in the DMZ ?, I mean it's a console it shouldn't be susceptible to anything should it ?, perhaps I'm wrong and I'm allways eager learn so if you could explain that would be cool.
