Intro:
So I wanted to go back to air for various reasons I won't mention. Anyway, I wasn't really interested in paying out the wazoo for a TR Ultra 120 + a quality 120mm fan + the pain to lap it...so I scouted around for cheaper alternatives.
I found the Xigmatek HDT-S1283 cooler...the heatpipes contact the IHS of the CPU directly like on the OCZ Vendetta, but the there's quite a lot more surface area for heat dissipation. I scored this for 33 shipped from somewhere in Sweden, I figure if OcUK can source this cooler it would end up selling nicely.
ANYWAY, on to my quick and dirty review of the cooler:
The box:
Contents: You get a 1300rpm PWM 120mm fan with some silent mounting rubber thingies, some AM2 bracket and the annoying push-pin S775 clips, in addition to a funky spoiler thing for directing some airflow down over your mosfets or whatever, a molex adapter, and of course thermal paste.
The Cooler: Just your standard finned heatpipe tower, except the heatpipes are on the bottom for direct contact with the CPU.
Fitment: I've always had water for my intel setups so I've never had to fuss with these weird mounting clips. Man are they super lame. Anyway, I finally got it fitted with just enough room for my HR-05
Performance: Well I tested by running 30 min of Orthos stress cpu.
The CPU is an e6300 @ 3.3ghz 1.4v
My water setup was: DDC 18w/Alphacool top, HE120.2 + shround + 2x120mm fans, 3/8'' tubing, EK wave CPU + MCW60 gpu, Swiftech Micro-res.
Ambient = 21C
Water
34c / 50c load
Xigmatek 120mm Cooler
41c idle / 54c load
As you can see, the Xigmatek is not bad at all especially when you compare the costs of each setup. Oh and also, the 120mm fan is actually very quiet even on full blast (1350rpm)...
The box:
Ambient = 21C
Water
34c / 50c load
41c idle / 54c load
