Stumbled on this review this morning, looks legit enough. Has some nice benches of the card using the X2 , GX2 Ultra and GTX in SLI to compare
Link Clicky
Link Clicky
I dont understand why they test crysis at high res when its so clear that the card hasn't the grunt to run the game at high settings. whats wrong with testing with playable( realistic ) settings instead of quoting unplayable frame rates and giving a % of the speed differance last time i checked 50% of **** all is errm...still **** all!.
Crysis
1680x1050- 0X AA/AF @18 fps
1680x1050- 4X AA/16X AF @12 fps
1920x1200- 0X AA/AF @14 fps
Most it out performs the ultra is 4% and most it is outperformed is by 24% by the ultra....
Sorry, either they don't say or I am blind, but what settings did they use for Crysis tests? High or very high?
They're not exactly unrealistic res's though, are they? Most people game at 168x1050 i reckon and quite a lot at 1900x1200...
Ok then....Of course the GTX and Ultra are faster than a slightly clocked 8800 GTS 512mb, as you can see once you crank the res up and slap the AA/AF on, the GTS gets left behind as its got a smaller bus, its only a 256bit, GTX/Ultra are 384bit.
Would've thought that'd be offset by G92's superior texture compression ratio and extra TMUs, though...
Crysis
