They should. I forgot to plug in my pump a couple of times after fiddling and it always shut down during the Windows loading screen. And each time it took a few reboots before I cottoned-on to what the problem was
MB seems to be the point of failure. Tried with a E6400 and had the same issue ie would start to boot first time then fail. Second fail at checking the proc.
Only got it in December so hopefully should still be covered by warranty, given that the proc shut down correctly (fingers crossed)
