Deleted member 651465
With curlers piled on top..
I've seen the pictures
I've got a Macbook pro I'm using at the moment so far so good - had to do a bit of unix fiddling to get it just right so far, and once I get my windows mobile to synch all the better - just need to try and see if it'll synch with some form of PIM and I'll be sold.
I quite like it thoughIt's got 3G, WiFi, built in GPS (ergo satnav) and all the apps in the world I could need - it'll be hard to replace!
I had to do some symlinks for the home folders to point to my NAS drive rather than to the local disc.
I also had to do a couple of other things I can't remember what now, but it hasn't screwed up my computer so it's all good!I'm not shy of the terminal window as I've been using Linux for a couple of years. (Though mainly the GUI).
Hehe - it's just so useful and does all that I want it to do so I doubt I'll be changing it
I've got an ubuntu box here that I use don't know if I can be bothered to install gentoo on it instead![]()
By "do what you want" do you mean do what you already do in Windows, or are you looking for something else?I'm thinking about taking the plunge. I'm using a MBP at home that I've borrowed, if I can get it to do what I want then I shall be getting myself one.![]()
Quick question - how did you find the refurb that you got?
Any problems or anything with it?
Recently decided to ditch the PC as well and go completely Mac, was using the Macbook far more than PC.
So, I got this...
[im*]http://img.skitch.com/20080715-ckg6nttdc3qng73fkqdq47rwri.jpg[/img]
And instantly set about upgrading it, so now its a 2.16Ghz C2D, 200Gb HDD and 2Gb ram. Even persuaded my 64 year old mum, now she's got herself an Imac![]()
