GTS Collision
25 Oct 2006
I am thinking of buying a GTS 512mb and I realise its quite long and dual slot. Below is a picture of my case and motherboard, I have a feeling that the second slot part of card will collide with the silver part next to my current graphics card. (I don't know its name :D )
Anyone with a GTS know if thats going to fit?
I think the old and new GTS cards are the same length aren't they? My old one only just hangs over the edge of a uATX board. Looks like it'd be okay if you moved a couple of cables over, can't quite see in that pic.
Yes it would be the south-bridge :D
By having no problems there do you mean the card will be over the height of the southbridge?
Also what would happen if it didn't fit, would I be able to return the card under Distance Selling Regulations ?
p.s case needs a dust
Shhh :p I need to get some compressed air.
Just a point, i dont think youre menat to use the molex and SATA power connectors on the hard drives
My drives have a warning on them telling me not to do it
