Software download for PS3?
no just the built in search, il try google
There is no built in search... unless you mean the one thats on the default home page? If thats the case your just searching the playstation web site so if you not searching for playstation related information no wonder you can't find anything :p
ive worked it out now :o i didnt realise you could just enter a web addy and do it that way :rolleyes: all sorted now, though im finding the font realy realy small because its on 1080i :o
Hey.
I backed up the data onto USB stick, and since I decided to get rid of linux as its useless I put the backed up data back on, but its telling me to register on playstation network again :confused: But we cant as its allready registered to the email, how do I get it back to how it was with it allready registered so we dont have to do it again? :(
Hey.
It doesnt normally affect your settings/login stuff as its saved in flash, so im not 100% sure. But you can just link the ID to your old one if you like, theres an option to do this in the sign up bit. Then you have to enter details email, password etc. This may sort out the problem, if not give us a bit more info and ill see if I ( or anyone else) can sort it.
