i'll have to get an adapter i guess
If you plug a shaver into ac mains (3 pin wall socket) with an adaptor your shaver will go pop. Possibly catch fire.
You plug it into bathroom shaver socket.
No it wont lol. A shaver two pin plug is still 230v, just very lows amps. Get a two-three pin plug adapter.
So how come the electric razor I have hasn't gone pop then when plugged into a regular mains socket with an adapter?
Don't worry, as long as your shaver is suitable for 240vac then a shaver adapter is the right thing to use. Perhaps the above poster had a yank shaver that he normally used in the 110v volt side of a shaver outlet and tried plugging that into 240v....
uhmm ok hrmm bugger ehh... dont have bathroom shaver socket... are they mandatory in all bathrooms in the UK??? Problem is when i bought it there wasnt really any indication that it was 2 pin only.
It has not been 240v in the UK for about ten years.
How many 3-pin shavers have you had? I've only EVER seen 2-pin.
just havent seen 2 pin ones either..No it wont lol. A shaver two pin plug is still 230v, just very lows amps and not earthed. Get a two-three pin plug adapter. You *could* cut off the two pin plug and wire it into a three pin one.
Why are they 2 pin anyway? An unearthed shaver in the bathroom seems somewhat dangerous....
