. There is more PSU's than in that list available to run SLI'd GTX's
im currently running 750w, i think that would be enough to power it however the two 6 pin connectors are being used
will having a bridge allow me to go sli? if so will it affect the 8800gtx's performance ?
however im not sure if i can buy another psu due to dells btx connector (see image above) if i cant upgrade my psu is there anyway i can still go sli by using a bridge for example, i only have 2 6 pin connectors and there both in 1 8800gtx i need another 2 6 pin connectors and if i cant upgrade my psu im stuck, will a bridge do the job and allow me to share the two connectors with another gtx?
The image that you have provided looks like a standard ATX 24-Pin Power Connector that would be located on any motherboard. If someone could clarify that would be great.....
