Try editing the FSX.cfg, look for:
WideViewAspect= set this to true
Just go for the tut missions. Everything else is just trial and error.I so want to get back into this game.
Are there any tutorial type DVDs for the game to help you along with lessons or to give you a breakdown of how to flight/flight mechanics/instructions/radio etc etc instead of wading through all the material provided in the help files in game?
I'm using Vista and there is no fsx.CFG on my system.
Hmm but I want to make sure that I learn everything correctly. I.e. to make sure I know what every dial does in the sim etc
Another thing which gets me... when you land at an airport, how the hell do you know where to taxi to? I mean I did use the radio feature which draws out a guidance line but presumably real pilots have no feature and are guided to specific gate numbers.
Or am I being too "rear ended" about it
I suggest that you go through all the tutorials provided in game, unless you want to start paying for extra book and DVD's. In my experience they are well worth reading through, and while the physical exams can be a little hard (Everything has to be perfect) they're worth a stab.
In regards to the taxiing, pilots have all the ground plates for the specific airport, if they are so unfamiliar that they need ATC help, ATC can provide "Progressive" taxi instructions, which involves the controller talking the pilot through the route, turn left on alpha, right on bravo etc.
Thanks for your reply Trill. I got a few questions if you dont mind answering?
1. Can you recommend any DVD's or books for FSX?
2. Not familiar with this term: "Ground Plates"? Pilot talk for map or something?
3. I remember the progressive taxi instructions in FSX, but this is laid out as a line leading to the gate though, does the ingame ATC actually give verbal commands as you have mentioned above?
Thanks a million
Oval dials? Have you selected a widescreen res, pretty sure the game supports widescreen.
