I cut one big circular hole in the bottom of the case and flipped my psu so the fan is on the bottom , this gives the extra cable length needed for the 8 pin connector to fit behind the mobo tray , also cut three more holes in the mobo tray , 1 for the 8 pin connector up at the top , 1 for the psu wires to go through to the back of the mobo tray and the last one up near the dvdrw drives.
also flipped the hard drives round the other way , had to use right angled sata cables and replace my power connectors with flush mounting ones so the wires dont catch on the fan!
As for the dust , try cleaning your room with a dyson, that way all the dust wont end up inside your case
ehhe right i think im gunna have to get some circular bits
