Go on, which £1k+ CDPs have you compared it to?
This is where their argument falls down; they believe the hype, not their ears.
I have had a beresford for about a month now and have to say im worried it was a waste of money. I just installed an audigy 2 zs and actually like the sound from the analogue outputs better than what I'm getting from the beresford. It might be because its slightly bright but it does sound nicer and more detailed to my ears. Im wondering if the pc cd drive just isnt showing off the beresford as much as a dedicated cd drive might. Im still left miffed though.
It'll have to be pretty damn good to beat the Primare I heard the other dayThis is where their argument falls down; they believe the hype, not their ears.
I'm having exactly the same issue, just got hold of an Audio Alchemy Dac-in-the-box to replace my creative external usb soundcard and i'm wondering what to think at the moment. The sound is a lot brighter as you said, with the benefits of a more clinical and detailed sound, but it just doesn't sound as 'full' as the external usb was.![]()
I think you misunderstood me, my audigy sounds brighter than the DAC. I think this might be fooling me into thinking the sound is clearer as the vocal is more defined. I think I can detect very slightly more clarity in the highs through the DAC but as I say the vocal is weakened by it. Im not sure if this is giving me a more accurate reproduction of what was intended, a more balanced playback, but the audigy sound is just better to my ears.
At the moment I am using a 3.5mm jack to dual phono connection from the audigy. Would it change anything to use a mono cable?
There also has to be a reason why phono is used over 3.5mm in most other apps.
