Caporegime
- 1 Mar 2008
How long will it take to do a full format on a 400gb Seagate?
In terms of gaming there aren't many advantages to either partitioning a drive, nor to formatting it as a compressed format. If you are hoping to speed things up by partitioning, think again. Due to the mechanical aspects of reading a drive, partitioning won't speed things up, and the compression will in fact make the drive slower. If you want a seperate partition for games, i would suggest buying another hard drive and putting them on there.
I would just put it all on the one 500gb in seperate directories. That way if you find you need more space for games and less for music than you originally planned, it makes no difference.
In different folders... eg. F:/Music, F:/Games, F:/Movies
EDIT: Beaten to it![]()
In my C drive can i put
program files
windows
drivers
in one folder called misc?
so its C:/misc/windows
C:/misc/program files
C:/misc/drivers
Umm.. No. You shouldnt really move the windows or program files or drivers folders as it can screw things up. In fact, you cant move the windows folder at all. You will just have to make new folders.
Or you could re format and create a partition just big enough for windows, and then have the rest of the drive for your other stuff.
