- 17 Aug 2003
- Woburn Sand Dunes
fakes. is that logo colour silver? senn never did that. i did warn you. do you ahve a picture of the packaging?
best phones around for under £100
X2 on Vanger's impressions. I have the C700 and X3i. The X3i has a little more bass, but nowhere near the detail of the Denons IMHO. The bass on the Denons is much cleaner and deeper. The highs are much brighter and less cymbalent too.
People have a harder fit with the Denons, but the foaimes fit them too!
The build quality is worlds apart. The Denons are built with a solid aluminum housing. The jack is also aluminum. The cable is thicker and much sturdier. The Mylars are all plastic and it will show. Jaben will replace them (over, and over, and over) which gets to be a pain.
The newer C751 are actually cheaper then the C700 right now:
Denon AH-C751
LOONG to send it back to singapore..
Which are the better? The X3s or the XBs?
Umm.. I seriously doubt that.
