Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
still there !
still there !
Every time I try to download something in installer I get an Error (Package Download Failed!)
I have tried force quitting the installer but this didnt help, it still sais error. I have 2 updates in the update section which are both the same, but both also have the same error.
Any ideas?
EDIT: If i restore fully, then ziphone it again........will i lose my contacts/music/all other data ?
how do i SSH ???
it is on btw in Bossprefs.
- Turn on SSH on your iPhone, if you haven't got SSH, download OpenSSH from the Installer.
- Make sure you are connected to a wireless network on you iPhone. Go to Settings > General > Network > Wi-Fi > Click the little blue arrow next to your network and make a note of your IP address.
- Next, open WinSCP, Fetch, Fugu or Transmit. Enter the following settings:
Hostname: You iPhone IP.
Username: root
Connect using: SFTP
Password: alpine or dottie (unless you changed the SSH password when you installed SSH)
Click connect.
And i take it WinSCP, Fetch, Transmit are programs i need to install in my phone ?
lastly, when did i install SSH ? don't remember that.
right, running WinSCP, where do i go in the program??
I put in the ip, login and password, but i can only see my other harddrives
