SwirlyMMS
iPlayer Link
Twinkle
WifiToggle
Sketches
Finder + Preview
BossTool
Mobile Chat
Colloquy
smartRSS (although I've never used it)
iSMS
SummerBoard
Battery
Services
Pool
Tap Tap Revolution
ScummVM
iSolitaire
iPhysics
Labyrinth
Sudoku
Lights Off
Mines
TuneWiki
Think that's it at the moment![]()
I've got a problem with twinkle. It never loads up my "tweets" it just says "loading for the first time" every time. The local function works fine, but not the home part.
Anyone else had this problem?
It did that for me until I had posted a few and had a few from other people; since then it's worked fine.
slightly off topic, but does anyone know how I can move the icons around on my main screen? thanks
I might bother you to send me a test later then, if thats ok.
Hold your finger down on an icon, they should start to shake/wobble. You can then drag them around.
*snip*
I'm using the same theme as you, but for some reason my weather icon is still the bright sun on the blue background, I just thought it had been left out!
