Aye yes you did! . . . . . . . . but you still posted it in the wrong section!I beat easy to it this time![]()
Have it in a GA-P31-DS3L mobo, Zalman CNPS9500 cooler, 2gb OCZ XTC PC6400 and 7600GT
This chip is nowhere near as good as my E8400; the E8400 will do 3.6GHz @ stock volts; the E7200 needs 1.375v in BIOS
CPU-Z reports 1.184 idle and 1.168 on load
This chip is nowhere near as good as my E8400; the E8400 will do 3.6GHz @ stock volts; the E7200 needs 1.375v in BIOS. SuperPI times @3.6GHz: E8400 - 12.8s; E7200 - 14.4s; E6750 - 14.2s.
If I wanted a cheap top performing dual I would probably go for the e8200 over the e7200. Will be interesting to see other peoples results though.I read some cool things about that Gigabyte board but is it really that good? I mean is it good enough to make that Wolfdale shine? I heard maybe it could use some attention to cooling as its quite bare?
Still its early days, look forward to your results and if u got time could you find out what the minimum vCore is to get that chip running at stock speeds pls!![]()
Am I missing something here? - I don't see these for sale on the Oc/UK website....![]()
i wonder how badly this chip will do in a p5w dh.
Boot into bios and go to advanced:
Under Jumper free Settings:
A1 overclocking set to manual
CPU frequency to 400 (higher later if that works}
Performance set to “Standard.”
PCI Express frequency to 100
PCI clock synchronization to 33
Memory Voltage to 2.10
CPU Core to 1.3-1.45v depending on overclock speed
FSB termination voltage to 1.4-1.5 whichever works
MCH voltage to 1.75
ICH voltage to 1.05
Hit ESC and go down to “CPU Configuration”
Modify Ration: Disable
Max CPUID: Disable
Execute Disable Function: Disable
CPU Thermal Control: Disable
Virtualization: Disable
Hit ESC and go to "Chipset"
Dram CAS to 5
Ras to 5
Ras to Cas 5
Dram Ras activate precharge [15]
Dram write recover to 5
Dram ECC: Disable
Hyper Path 3: Disable
Dram throttling: Disable
Memory remap: Disable
Probably not as bad as you think, a few peeps have managed to get wolfdales stable at 4Ghz using the P5W DH Deluxe mb. This is a copy paste of the settings used to run an E8400 at 3.6GHz on a P5W DH, would imagine them to be pretty similar to what you would use for an e7200....
will give it a go once i have money
Just been looking at these on the ocuk site. It says on there that they have an 8x multi which i thought was odd because that would mean 317*8. I currently have an e2180 at 320*10. I know my board will do 400fsb (ga-p35-ds3l) but I haven't tested above this. That would only give me 3.2ghz, the same as i run now, so not much of an upgrade. If they have a 9.5 multi then i might have to consider getting one of these![]()
