Poll: Steak
How do you like your steak?
  • Blue (the manly way)
    Votes: 48 7.2%
  • Rare
    Votes: 103 15.4%
  • Medium rare
    Votes: 230 34.3%
  • Medium
    Votes: 125 18.6%
  • Medium Well-done
    Votes: 68 10.1%
  • Well done
    Votes: 77 11.5%
  • Cremated
    Votes: 20 3.0%
  • Total voters
    671
Good cut of Fillet has to be blue, i eat my duck / venison / ostrage etc the same way.
How steak should be served (on the stone at the Nurburgring) :
I don't like a chewy steak, so well done to cremated for me, although I have gone for medium on occasion.
This depends totally on the cut of the meat and it's standard. A decent piece of meat can be rare and not chewy at all, but a lesser cut of meat may need a bit longer to be tender enough.
Burnsy
Blue (or Bleu) for me, but as I have stated before I am very choosey on my size/cut of meat, might goto the butchers tomorrow so if I do I will post more pics of good quality meat.
But untill then
KaHn
Never seen steak cooked blue before, looks better than I expected. Whats the minimum length of time you can get away with cooking steak then, on a very hot pan? 30 secs a side?
In Canada I've had roast meat cooked the way Heston Blumenthal (sp?) must have cooked his steak. They have ovens set up at exact temperatures and cook the meat very slowly. So rare might be 65deg's Medium 70deg's and well done 80deg's. The entire cross-section of the meat is then cooked to that consistency. It was very very good.
You don't have to cook it at all. It depends what you want.
65 degrees Fahrenheit I presume? As Celsius well that would be awful! lol
Centigrade, I don't think he gets the meat above 70
No because the protiens don't start to transform until 60 odd degrees I think. I'm not biochemist but as I understand it cooking is the heat related transformation of the protiens and these apparently begin at 60 deg's Celsius (in Beef). The difference is with the oven set exactly to this temperature it takes log time for the heat to diffuse throught the meat. On a griddle the temperatures are higher and you rely on thermal gradient. The oven cooked meat is like the boundary between the seared and the raw meat in a griddle cooked steak.
Or at least that was the very convincing discription my surgeon friend gave me when were discussing the subject and tallied with my own understanding.
But but but but a blue steak isn't suppose to be hotter than mid 30s!!!! :( :p
Care to explain what this transformation of proteins do?
Fusion - it depends on the cut of meat, thickness and quality of the meat. Furthermore if it's been tenderised, left outside the fridge for a while etc... It's not raw, raw steak is steak tartare which has it's own preparation and is very different to a typical steak.
THE STEAK
Serves 2-4, depending on how hungry you are
1 well-aged, two-bone fore rib of beef (on the bone — ask your butcher) Black peppercorns
Sea salt
Smoked sea salt
Groundnut (peanut) oil
1 Using an oven thermometer, preheat the oven to 50C/120F/Gas Mark .
2 Place the fore rib in a roasting tin. Brown the outside as quickly as possible using a blowtorch. (If it’s not hot enough, the flame will start to cook the flesh. If yours isn’t up to the job, use a very hot pan instead.) Once the meat is browned, place it in the oven. Use a digital probe to establish when the internal temperature of the meat has reached 50C/ 120F (this takes 4–8 hours, depending on the animal; don’t let it go any higher — it will ruin the recipe), then let it cook at this temperature for a minimum of 18 hours. Remove from the oven, cover and leave to rest at room temperature for 2 hours — 4 would be better — it’s important that the meat cools down before it is subjected to the fierce heat of the pan.
3 To prepare the steaks, hold the fore rib upright with the rib bones side on. Run a sharp knife between the meat and the bones, and free what should be an L-shaped piece of meat. Trim off any overly charcoaled exterior. Slice the meat in half vertically to give two steaks, each about 5cm thick.
W of the steak, it kick-starts a complicated process known as the Maillard reaction, which adds depth and complexity to the flavours of meat. To get those flavours without drying out the steak, you need to brown the surface quickly and then take the heat right down. At the lower temperature, muscle proteins contract and squeeze out water more slowly, which is crucial to
keeping the meat moist. But the steak also needs to be tenderised, which, at this temperature, is done by enzymes that weaken or break down collagen and other proteins. Heating the meat slowly means these enzymes can perform their magic for several hours, effectively ageing the meat during cooking. The result is the tenderest, tastiest steak imaginable.
4 Place a large cast-iron pan over a high heat for at least 10 minutes. Meanwhile, take the blue-cheese-infused butter out of the fridge and remove the cheese. Crush the peppercorns using a pestle and mortar, add a little of the plain sea salt and smoked sea salt, and put this mixture on a plate. Dip both sides of each steak in the seasoning.
5 Add a film of the groundnut oil to the pan and, when it’s smoking, add the steaks. (The surface of each steak needs to be in contact with the pan, otherwise they won’t cook properly. If they overlap, fry one at a time.) Fry for 4 minutes, flipping every 30 seconds. They should develop a nice 1mm brown crust, while the interior should be uniformly pink.
6 Let the steaks rest. Allow the frying pan to cool slightly, then add the flavoured butter and stir to melt it and collect any bits of meat that remain. Pour into a jug.
7 Cut the steaks into diagonal slices. Add a few grindings of black pepper, and a sprinkling of sea salt and smoked sea salt, then drizzle the butter on top. Serve with a dollop of mushroom ketchup and tomato ketchup.
