 - 13 Jul 2006
 - Hell!! \m/
Home/Bargains sell them for like 19p.  You guys should make a video using your British accents, it'll be a lot better than the boring ones.
			It's not what's in the mints, it's the pattern and size of the dimples on the outside of it, apparently.
there everywhere
Really? How would it affect the reaction?
it's basically that the higher surface area provides more nucleation sites allowing more bubbles to form.If it is the bumps on the mentos, then I guess the increased surface area would be working as a sort of catalyist, allowing the dissolved CO2 to coagulate. Only guessing though, could easy be talking complete trash.
Find out?wouldnt the process be quicker and more dramatic if you ground the mento's into a fine powder and poured it in?
nope.wouldnt the process be quicker and more dramatic if you ground the mento's into a fine powder and poured it in?
What if you ate several mentos without chewing them, then drank a load of diet coke. Would you explode?
you are supposed to drop afew in the bottle, put the lid back on and shake it
then slam it down cap first on a hard surface so it blows off
like this
like this
like this
