B-Grade
It may be everything, it may be just the card. I bought a mobo, and it was just the mobo, np I/O shield nothing. But then, i wasnt really bothered, cheap was the key!
At the end of the day, you get what you pay for. The more that it's reduced the less that you'll get with it. You can always send it back if it doesn't work or isn't up to the standard you want. I do think there is a reduced warrenty on the items, but someone else will have to confirm this.
PK!
I bought a B-Grade P35-DS3L for £25 and the only thing missing was the onboard speaker.
Excellent bit of kit!
Happy Days :D
Happy Days :D
Saves you putting a screwdriver through it I suppose.
Hateful things.
(screwdriver through it is better than just not connecting it, it still makes a strangled croak, enough to provide clues when it won't POST, but not enough to drive you insane)
Bought a b grade monitor and instead of £305 delivered it was only £223 :)
Nothing came with it though...no power cables or vga/dvi cable or manual..glad i didnt pay £80 for them :)
Monitor itself was 100% perfect so definately a very happy customer.
i ordered it , and so did a few other people it seems. They've all gone. theres not much in a GFX card box anyway. so long as it works.
Just noticed this in the B-Grade listings, surely this is not right???
AMD Athlon 64 3800+ Venice 90nm (Socket 939) - OEM
£82.24 inc VAT :confused:
Under it is this...
AMD Athlon 64 4000+ San Diego (Socket 939) - OEM
£30.54 inc VAT
Hence my question!
