I'd go for the Powercolour one, 512Mb Pre-OC'ed and the cheapest of the 512Mb versions....
Gurusan - What happened to you crossfire setup? Was thinking about pairing my HD3850 with either another 3850 or a 3870. How did you find it?
i sold the 3870 because it was too much power really....
And crossfiring the 3850 and 3870 worked out pretty well, I clocked my 3850 to 900/2160 and the 3870 to 850 and it really performed well.
yup.
Anyway, back to the OP....the HIS IceQ3 versions are fairly quiet....also powercolor makes a fanless silent one...but unless the airflow is very good in your case I would recommend strapping on a 120mm fan or something..
Or, you could always buy an Accelero S1 cooler, they are very cheap, very good, and fanless![]()
even if you are a mild gamer, the 3850 is a million times better than the 3650 in games.
