ASUS R.O.G. Maximus II Formula (Intel P45) pictures
Caporegime
6 Dec 2005
Birmingham
source
Looks good! is that what happens when you overclock to much!!! (bottom right hand picture) :o:D
do we really need 16 phase PWM?
& does it really run 16 phase all the time or drop down to e.g. 8 except under certain conditions?
interesting that they have gone X-Fi or onboard sound.
Worse really, has less PCI-E lanes available for multiple-GPU setups. Comes with the newer ICH10 southbridge though.
You know, it may be absolute balls, but people will still buy it because....well, that has to be the "coolest" looking motherboard I've ever seen :p
If a motherboard can look cool :p
Yet another awful heatsink contraption. It's so clearly desinged to work with the stock Intel cooler yet the group of people this board is aimed at will either be on water or high end air, neither of which will supply those heatsinks with the cooling they need. It also look's like it won't be so easy to replace that one with heatsinks or waterblocks. The NB would be ok but the SB one is huge. Does that have an extra chip under it so it can supply two full speed pci-e 16x lanes?
Would most people go for P45 over X38 or even X48? I'm just thinking is the X series that much better now the P45 has ICH10/R?
The X48's are the higher end boards. P45 is an upgrade to P35, which are lower-specced boards. The X-series isn't MUCH better at all unless you use crossfire (I don't), so for 99.9% of people a P45 will be fine for them.
In practise the performance differences will be negligible though I expect.
965 -> p35 -> p45
975 -> x38 -> x48
That's the upgrade path, with the 1st line being the cut down versions of the 2nd line.
Love the look of the board, but the practicality of it is just silly, as has been mentionned, this board is going to be aimed at users that will not be using a heatsink/fan combo that blows onto the cpu. Water would be hell to use also, bet it'd take a while to get all that metal off!
965 -> p35 -> p45
975 -> x38 -> x48
Without being a pedant wasn't 975 just the poor prelude to 965? I'm sure i remember 975 being generally quite a bad clocker without many "premium" boards availible, whereas 965 was a beast with lots of "premium" boards.
Are there heatpipes underneath those heatsinks? There's one visible going to the PWM's from the northbridge.
as it most likely will be a common PWM design across most of their P5Q boards this may be a bit of an answer:
"The P5Q3 may report the use of a 16-phase PWM but we know better. Although ASUS design engineers have added a lot of extra chokes and MOSFETS, the overall capacity of the power delivery circuit remains comparable to their competitors' more modest 8-phase designs. One thing's for certain, we can all agree that more phases do not necessarily make for a more stable power subsystem. Although we did not experience any problems with this particular solution we would rather see ASUS concentrate their efforts on designing an entirely new circuit based on a true 6-phase PWM."
http://anandtech.com/mb/showdoc.aspx?i=3309&p=2
975X doesn't reach the same high fsb as 965/P35 etc. (typically middle 400s with a C2D & mid 300s with a Quad) but it's a faster chipset clock for clock e.g. if you had a 965 & a 975X both running an E6400 @ 8x425 the 975X would give better results.
