FreeNX or Remote desktop software for Windows?
15 Feb 2003
Europe
Is there something like FreeNX for windows?
We have a PC running as a print and fax server sitting the corner of our office. The people in my office need desktop access to this PC without being physically at the machine. For Linux to Windows I use FreeNX but what options are there for a Windows to Windows PC?
Thanks
Hi
For Windows to Windows you can use the Remote Desktop application - make sure the Print Server has the Remote Desktop Enabled (Right Click My Computer, Properties, Remote Tab), then on the Client PC use the Remote Desktop Connection application (XP/Vista built in - Sub 2000 need to download the client)
Rob
Unfortunately that does not work - remote desktop can only be used on a host when running XP pro or above. This computer is running XP home and will not be upgraded.
Are there any other software alternatives?
As above, specifically VNC Enterprise Edition ;)
http://www.realvnc.com
30-day free trial included as standard, try it out; If you'd rather not purchase, use VNC Free Edition / Ultra VNC
install tightvnc server on that machine, then download realvnc setup on another machine, extract 'vncviewer.exe' from this, and give that exe to all the staff that need to connect to it
vncviewer.exe can be run standalone, and is the best combination i've found :)
I know you said they need desktop access but is it not practical to serve the printer over samba and also the fax, depending how the fax server works (if it emulates a windows printer you could share this over samba too)?
nah no chance - I'm leaving in two weeks and want to make things simple for them. The users will be 4 middle aged women - Think they've enjoyed having a young guy around. Anyway they have no clue about linux or most other computer related things and the boss won't stump up any cash. They do have basic windows xp knowledge and know a man who can work with XP if they get into difficulties after i leave.
I'll give tightvnc a go as normal VNC didn't appear to work it says not accepting connections after I wouldn't let it connect to the internet - I only want to use this locally you see.
you have to allow it, it won't be used over the internet, unless a port is forwarded to it (through the router)
allow it in firewall or it'll never work, it's using tcp/ip so you have to allow it
"Not accepting connections" suggests you've configured VNC not to listen on port 5900 (effectively disabling it), you'll need to ensure it's accepting connections; It won't be able to accept connections from the internet unless you configure port forwarding, so don't worry about that. You will however, need to open TCP 5900 in the firewall of the VNC Server machine.
thanks - tightvnc did the trick - but even on a local LAN connection its nowhere near as quick as FreeNX on a WAN conncetion
TightVNC uses the old VNC Hooks capture method, they also use lossy compression and the performance is negligible.
Download and try VNC Enterprise Edition;
VNC EE uses the VNC Mirror Driver (a secondary graphics driver installed onto your machine) and provides greatly improved performance over that of VNC Hooks/Polling
