Until recently I have been using 'Full' mode for RGB Full Range on my PS3, that was until I discovered my TV didn't support it, so what I thought was a properly calibrated TV, actually wasn't, I was loosing a lot of detail in dark areas of movies and games.
So how can you tell if your TV Supports RGB Full Range? - Many HDTV's do not!
What your about to read is blatantly stolen from andrewfee on the NeoGAF forums.
Blu-ray & HD DVD Calibration Disks
Might seem like a lot of effort, but by doing the above you know your getting the most from your equipment, now GTA4 isn't too dark at the default settings.
Once you have discovered if your TV Supports Full Range or not, it would make good sense to calibrate it correctly. Below is a link to AVSForum which provides test paterns that you can burn to DVD, and instructions on how to use them.So how do you find out what your display supports? Well if you're hooked up to a monitor, it's 99% certain that it will be expecting a Full RGB signal.
So how do you know if your TV supports it? TVs generally have a hard cut-off on the 16-235 range, turning anything outside that to pure black / pure white. (eg 15 would be jet black, no matter how high you set brightness)
Make sure your PS3 is set to limited and download this image onto a memory stick, load it up in the PS3 browser etc:
http://sr-388.net/images/patterns/Brightness.jpg
Turn up the brightness control on your display until you can (hopefully) see all four numbers. (1% grey, 2% etc) Assuming you can see all four, adjust brightness to the point where 1 is just about to turn solid black. (if the lowest number you can see is 2, then adjust it until that is almost black)
Now, enable Full RGB. If your screen supports it, you should still be able to read the same numbers. If not, it will turn pure black. However, many TVs that support both won't auto-switch between the two, so you may need to check your TV's menus for a "black level" setting. (may be called something different) If you have that, change it and you should see the numbers pop back up onscreen.
If you can't see the numbers at all when you enable Full RGB and don't have any options that bring them back, you should be using limited. If you can still see them all, you're probably fine using Full RGB.
If you do use Full RGB, check your contrast setting is ok. If it is set too high, you may not be able to see the 99, 98, 97, 96% grey in this image:
http://sr-388.net/images/patterns/Contrast.jpg
Note: Just because you may be able to max out contrast and still see all the numbers does not mean that is the correct setting. This can only tell you if it's clipping highlight detail, not if it's too bright.
