Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Then just have the ring, i only have the ring.
I assume it's an Orange thing as it doesn't do that to me.. have you tried checking your mailbox options in your Orange voicemail?
If you set that, then you'd never be able to see the rest of the details for that contact or ring any of the alternative numbers... which would be a bit daft.1. When selecting a contact to call from your contact list. You press the contact, you get their details come up and then you have to yet again press on the telephone number.
Is there noway to get iPhone to dial the defaul number assigned to the contact?
You can add a specific number to your favourites list. Anything you hit in your favourites rings the number you added straight away. It also adds the number type (mobile, home etc) after the name so you know what you're about to ring.
Anyone got any good ringtones for txt/calls?
As long as it makes a noise, it's a ringtone. You don't need Dizzee Rascal to rap at you for a few minutes, chances are your caller will get bored. THEY don't get to listen to Dizzee Rascal.
Thats what I thought, but while SSH'ing I saw that there were still folders left from Apps that I had uninstalled. Plus, I'm a little pedantic with things like thisCan't you just uninstall the apps you don't want? I don't think its like a PC where a format causes the computer to run faster![]()
Thats what I thought, but while SSH'ing I saw that there were still folders left from Apps that I had uninstalled. Plus, I'm a little pedantic with things like this![]()
When you sync with iTunes it backs up SMS and lots of settings too. Even icon positions!
You could do a restore, then re-unlock/jailbreak then install the stuff you just want.
